Hi there i am not sure if is hould post it here of in forwarding protocols. But anyhow here it is.
Here i something i would like to try but first i want to find out if it will work.
Currently i have working wifi network running ospf, the ip range is 172.23.128.0/24
Now here is what i want to do…
1.Run second private network(10.0.0.0/24) on same wifi network.
2.Hide the networks from each other, they should not be able to exchange packets etc.
3.Use 2 ospf rules. One for 172.23.128.0/24 and one for 10.0.0.0/24
Have someone tried something like this before?
Can ospf be set so that it only shows routes for example 10.0.0.0/24? I dont want the client routers that wil use the 10.0.0.0/24 to be able to see the 172.23.128.0/24 network.
Bisically rather than using 2 separate link for my 2 networks i would like to use my existing link for this.
