Run a script every 3rd of the month
Hi Guys,
I need a script that will run every 3rd of the month.
I now i can schedule to run every 4 weeks etc but how to run every X of the month??
Maybe run once a day and check the date then parse the day then do what I need to do???
If so how to parse the date..
I would do the same as you suggested: schedule a script to run every day and check the date, and if day of the month is equal to 3 then proceed with whatever you wanted to do.
So, you need to declare variable for a day of the month in order to proceed. For example:
:local date [/system clock get date]
:local day [:pick $date 4 6]
:if ($day = "03") do={
BODY OF YOUR SCRIPT
Perfect.. works great
thanks
