Run Capsman on Routerboard 2011iL-RM when not used as router possible?
Hi, I have a Routerboard 2011iL-RM that I’ve been using as a router for around 5 years. Now I want to use a different router, however I’ve got 8 cAP ac connected to Capsman on that router. How do I connect the RB2011iL-RM to for example a switch to continue using it as Capsman? Connect to WAN-port or other ports, and/or what settings do I need to change? I couldn’t find the answer using Google.
Edit: I forgot to add: Should I rather run Capsman on one of the cAp ac’s instead, if that is possible?
