I am relativ new to Mikrotik. I want to run a script every minute but only between only between 03:00am and 04:00am.
When I see it correct the scheduler can run commands only in an intervall but not in a timeframe.
Does someone has an idea how a script should look like which I can execute with the scheduler every 2 minutes. I assume there is a way to make this script first check the time and then execute the command when it is between 3 and 4
