Is it possible to run two versions of CAPsMAN on the same router (CCR2004)?
My scenario:
I have a CCR2004 currently running CAPsMAN Legacy managing 30 access points. I need to integrate new access points (C52iG-5HaxD2HaxD), which require the new version of CAPsMAN.
Can I set up a new CAPsMAN instance for the newer version on the same router while keeping the existing CAPsMAN Legacy configuration active and running simultaneously?
Best Regards,
Carlos Eduardo Diasd
