I am trying top run ftp services on non standard ports.
I wonder is there any limit in ROS? And what is the correct approach?
Example:
I want to run ftp service in the following ports
port 711 → to host 1
port 721 → to host 2
port 731 → to host 3
port 741 → to host 4
port 751 → to host 5
> ip firewall service-port print
# NAME PORTS
0 ftp 21
1 tftp 69
2 irc 6667
3 h323
4 sip 5060
5061
5 pptp
I have a feeling that I need to define ports 711,721,731,741,751 as a service port or it is enough for correct NAT-ing that I define connection-type=ftp?
Earlier, using iptables the correct module load took care of it:
You can add your custom ports to service ports under FTP and it should work. But only for non-encrypted connections. For encrypted ones (SSL) you have to manually forward fixed port range for each server and make them aware of that. And I don’t think you need connection-type=ftp in your rules.
What I’m missing here that ROS should be aware that the dst-nat-ed connection is ftp type and to automatically handle it as an ftp specific connection whatever it means in NAT rules (like allow and forward related etc. use port 20 etc)
Maybe it is more complicated to set up in ROS… but if ftp works perfect on port 21 the same rules should be applied to some other non standard ports.
Yes, if you want the NAT helper to handle things automatically (recognize related data connections and rewrite addresses), because it only looks for FTP protocol on specified ports. Not needed with manual setup (static port ranges for data connections).
Your problem is “connection-type=ftp”. It matches related connections, not the main one.
I have no idea about the limit, if it’s simply because inspecting traffic on many ports means more work and is therefore not good for performance (so kind of “8 ports must be enough for everyone” :), or if it’s something else.
There’s always possibility to stop relying on NAT helper and doing it the manual way. So for server one you’d forward port 701 for control connection and e.g. 10000-10099(*1) for data connections. For server two it would be 711 for control connection and 10100-10199 for data ones. And so on. Then you’d have to configure backend servers to be aware of that, so they would return correct address (your public one) and ports from their assigned ranges to clients. All modern FTP servers can do this.
Advantages:
router does not have to inspect contents of FTP packets and do any address rewriting
it works with SSL
Disadvantages:
additional configuration on servers, but it’s one-time only
whole data port range is always forwarded, you can’t do any filtering based on ‘related’ match
(*1) - The number of needed ports depends mainly on server load, e.g. small home server can happily work with less than ten, large server may need thousands.
