We bought a couple HP Ml 350 Servers that only have SMART ARRAY SAS Controller
So the only way to run RouterOS is install it in USB thumb stick.
Yesterday i just installed and its running well but i´m worried about reliability. These Servers have an internal USB Connect só the thum stick stays inside the Server Case.
What do you think about reliability of running mikrotik as a core router running on a thumb stick . i´m using a Kingston 4gb Stick.
