While updating the configuration via TR69 or importing manually, I get an error “runtime limit exceeded” and the conf is not entirely applied.
In the conf I have some delays, “:delay 10s;” about 50s in total.
It happens on Mikrotik Chateau or CCR2004 running version 7.1.1, 7.4.1 or 7.5.
Someone knows how can I find the value of that limit? Or how to bypass it or increase it?
CCR1072, FW 7.11.2 same problem: “runtime limit exceeded”.
But without :delay instructions. It is simple a big script (~10500 lines, generated by export).
It must be executed with the reset config because it kills temporary the connection.
I woud need an option to set an alternative timeout for this run.
