The setup:
Followed the setup example @ https://wiki.mikrotik.com/wiki/Manual:IP/IPsec#Road_Warrior_setup_using_IKEv2_with_RSA_authentication
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
/ip ipsec mode-config
add address-pool=rw-pool address-prefix-length=32 name=rw-conf static-dns=8.8.8.8,1.1.1.1 system-dns=no
Problem:
I am establishing successfull connection to my router via ikev2 VPN with the generated certificate, but i can’t access any websites. I do have ping to the IP of the domain and
traceroute goes through as it should, but the dns is not resolving.
Example:
When VPN is active and connected
Pinging x.x.x.x with 32 bytes of data:
Reply from x.x.x.x: bytes=32 time=12ms TTL=60
Tracing route to x.x.x.x over a maximum of 30 hops
1 8 ms 7 ms 8 ms def-gateaway x.x.x.x
2 12 ms 42 ms 12 ms ips x.x.x.x
3 13 ms 12 ms 13 ms 178.132.83.58
4 * 13 ms * 178.132.83.58
5 12 ms 12 ms 12 ms 78.128.126.162
6 12 ms 13 ms 12 ms destination x.x.x.x
In Chrome:
DNS_PROBE_FINISHED_NO_INTERNET
Why the dns isn’t resolving the domain?
