Hello, I want the filter I want to be active when the sfp-sfpplus1 port is over 50 mbps, then I want it to be deactivated again after the second I set.
/interface monitor-traffic sfp-sfpplus1 do={
:if ($“rx-bits-per-second” > 50 ) do={
/routing filter enable 5
:delay 5s
/routing filter disable 5
I did as above but without success. how can i do i need your help thankyou.
