I’m having issues with Rx Drops/Errors on my RB750G.
I currently run 2 MLPPP fiber lines to ether1/2, while both lines are in MLPPP mode, my download speed is around 25000kbps, and i receive around 100 Rx Drops/Errors per minute.
If i configure the MLPPP to use 1 line only, i see no errors and my download speed is as expected, around 38500kbps.
Previous to this issue both lines where working fine and i was achieving download speeds of around 79000kbps.
I’ve swapped out all my cables, and swapped around my VDSL2 modems, and both give around 38500kbps download speeds while connected separately to Ethernet port 1 or Ethernet port 2.
There have been no configuration changes on the RB750G almost a year ago.
Has the RB750G become defective?
