Rx FCS ERROR
I have the following problem: rx fcs error, I already changed cable, port, router is in version 6.43.14. But the error always appears, has no date and time set, occurs once a day, 5 times a day, there is a day that also does not happen. Has anyone ever faced this problem?
Many people have faced FCS errors many times, some notice it and some don’t. As you say you’ve replaced the cable and used a different port, the reason can be
  • interference (strong electro-magnetic field)
  • the contacts of all ports of your Mikrotik corroded or dusty, causing unreliable contact
  • an issue with your power adaptor (dry capacitor)
  • an issue with the device to which the Mikrotik is connected
