After installing version 3.23 I see many RxDrops on my ethernet interfaces(Intel 82572EI).It is some problem or what?
isn’t this because versions prior to 3.23 did not show that information? =)
ok.why RxDrops may accour?
Many possibilities. The most common are Ethernet collisions from duplex or speed not matching. Also bad cables, using a hub and not a switch. Using half duplex.
Tom
