1 - doens’t show any data inside these fields from SFP tab
2 - in the same tab, the “Module Present” checkbox is aways oscillating between checked and unchecked
3 - Poor Signal - using any fiberhome’s onu the signal rate is -18dbm:
when putting a Mikrotik’s S-GPON-ONU on a RB, causes signal loss to -48
4 - Limit MTU Size 1512 - NO VPLS!!!, - FIBERHOME’s OLT Supports a 2048 bytes MTU size using a Bridged onu AN5506-01-A1
Well - today I finally got a Mikrotik (( 2011UiAS-2HnD )) with a Mikrotik GPON SFP talking to my Adtran TA-5000 head end.
You can pretty much forget about using google for help on this topic (Mikrotik GPON to Adtran) — I found nothing after a month of searching.
What you need to do is configure the head-end for your GPON network to treat the Mikrotik GPON SFP module like a regular GPON bridge device (NOT a residential gateway).
The Mikrotik SFP interface does NOT need a vlan - - Treat the Mikrotik SFP interface with the GPON module inserted just like a regular Ethernet connection.
FYI
I still have a lot of work to try and test. I want to get it to pass vlans - and possibly get a SubH (out-of-band-management) working on my Mikrotik.
North Idaho Tom Jones
FYI — Mine also does not show any data inside these fields from SFP tab
