Hi.
Got S-RJ01 and it switches from link ok to no link.
Is it broken or I should use cross-over cable?
Isn’t it supports both type of cables? Or I should switch it some how?
Hi.
Check your auto-negotiation settings, they should match on both sides. Also check your cables. What devices are you connecting together?
