S-RJ01 SFP+ compatibility
Hello all,
I would like to ask, whether the S-RJ01 is compatible with the SFP+ cages found on the newer CCRs, namely with CCR1072-1G-8S+. On the product info site of the CCR1016-12S-1S+ is mentioned, that the SFP+ cage is compatible with SFP modules
SFP+ cage supports regular SFP (1.25G) modules as well
, but I need to be sure.
ping
On CCR1016-12S-1S+ they work fine at SFP+ port.
But be careful there are two version of S-RJ01 - one I got with my CCR1016-12S-1S+ is terrible. It does not work with SFP+ and also often not able to link at 1G full duplex. It does not have a screw on the top cover.
Another version (this version has a screw on the top cover!) works fine with SFP+ and has no problem at all.
