Since the RB/433GL’s are having issues with throughput, and I don’t have time to wait for a firmware fix, I thought about going back to the 433AH’s, but I like the GB ports because I can push 130Mbps on my PtP links. I see the RB/435 is a good candidate for this, BUT is has an extra 2 nonsense PCI slots on the back, making it impossible to put in a case.
I remember seeing somewhere online there was even a company that de-soldered the PCI slots so you could use it. I know I could use a huge outdoor case, but these ones I"m replacing are inside cases in a outdoor cabinet. Those huge white outdoor cases just wouldn’t fit.
Anyone have any luck removing those extra (2) slots? What a pain! Who uses (5) mini-PCI cards anyways!
Removing the 2 PCI slots on the back is being done already by Baltic Networks, as shown in the link. As mentioned in my post, it is only a “inconvenience” have them on there. "I’m sure the board works fine with them, its just a pain to try and fit it in “most” of the indoor cases. Even the popular outdoor model ODE-MTK you can only screw in the bottom screws, the top ones won’t fit because the 2 bulky PCI slots prop the board high off the back plate.
