The problem is the same with a scan list well populated and dfs enabled in “no radar detect” or in “radar detect” the ap choose the first frequency also if it is used by a close ap.
Reagrds
Reagrds
Another AP is not considered as a radar activity so your AP can use that freqeuncy.
so what “dfs no radar detect” means?
so why using that features on 2.9.xx the AP choose the best frequency?
Ho to let AP choose the best frequency, available on scan list, on v3?
Regards
Ros
Runing beta8 RB112 test setup about 40 feet one of my towers. DFS mode=no radar detect. If I watch the status while enabling the interface the frequency will change several times and settle. This matches the best that the scan shows. In my tests it picks a frequency with less than -95 of other APs.
me too…
but unfortunately it get 5500 that it is just used.
This is not happining on 2.9
regards
