We are looking at getting some more Rb532 from mikrotik, but we have a few questions:
We haven’t ever got any wireless cards off you before so a few questions about this:
The Mikrotik Hotspot Access Point, is the antenna detachable, if so what connector does it have, n type, sma???
The wireless cards, which is better, CM9 or R52?
Do the wireless cards, CM9, R52, SR5 come with a connector cable? (i.e. to SMA or ntype) - If not do your sell this separately, how much are they?
How many wireless cards can you fit in a standard RB532?
Do the expansion cards require a larger housing than the standard RB532 housing?
normis
2
- The Mikrotik Hotspot Access Point, is the antenna detachable, if so what connector does it have, n type, sma???
what device do you mean, link?
http://www.mikrotik.com/pricelist.php
- The wireless cards, which is better, CM9 or R52?
it depends. very similar
- Do the wireless cards, CM9, R52, SR5 come with a connector cable? (i.e. to SMA or ntype) - If not do your sell this separately, how much are they?
look in the price list, link above
- How many wireless cards can you fit in a standard RB532?
i suggest you read the specs of the product that interests you:
http://www.routerboard.com/rb500.html
- Do the expansion cards require a larger housing than the standard RB532 housing?
if by expansion card you mean the two miniPCI cards that can be fitted inside the routerboard, then the answer is No
