Hi
I have two client routers configured for site-to-site access (engineers at the office can connect to devices installed on client sites).
On main site, there is SSTP server, both client routers are configured to connect over 4G LTE modem (PPP protocol) and SSTP type VPN.
On site1, it is possible to ping connected devices, on site two it is not.
The difference is that, on site 1 hardware is RB951Ui-2HnD, on site 2 the hardware is RB951Ui-2nD. Same firmware, same software version.
I have no idea, what is wrong…
the configuration scripts:
site1
# apr/10/2017 13:27:38 by RouterOS 6.38.5
# software id = 5SVQ-YCPK
add admin-mac=6C:3B:6B:E3:79:3E name=bridge1
set [ find default-name=ether1 ] name=ether1-wan
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=poland disabled=no frequency=auto mode=ap-bridge ssid=**** wireless-protocol=802.11
/ip neighbor discovery
set ether1-wan discover=no
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=**** wpa2-pre-shared-key=****
add name=dhcp ranges=192.168.118.100-192.168.118.200
add address-pool=dhcp disabled=no interface=bridge1 name=dhcp1
/port
set 0 name=usb1
/interface ppp-client
add apn=internet dial-on-demand=no disabled=no name=ppp-out1 port=usb1
/interface sstp-client
add authentication=mschap2 connect-to=**** disabled=no mrru=1600 name=sstp-out1 password=**** profile=default-encryption tls-version=only-1.2 user=**** \
verify-server-certificate=yes
add bridge=bridge1 interface=ether2-master
add bridge=bridge1 interface=wlan1
add address=192.168.118.1/24 interface=ether2-master network=192.168.118.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1-wan
add address=192.168.118.0/24 gateway=192.168.118.1 netmask=24
add action=masquerade chain=srcnat out-interface=ether1-wan
add action=masquerade chain=srcnat out-interface=ppp-out1
add distance=1 dst-address=192.168.10.0/24 gateway=192.168.2.254
add distance=1 dst-address=192.168.11.0/24 gateway=192.168.2.254
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=****
/system ntp client
set enabled=yes server-dns-names=tempus1.gum.gov.pl,tempus2.gum.gov.pl
/system routerboard settings
set init-delay=0s
site2
# apr/10/2017 13:27:35 by RouterOS 6.38.5
# software id = MD8S-ESJH
add admin-mac=6C:3B:6B:50:0E:76 auto-mac=no comment=defconf name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce country=poland disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=**** wireless-protocol=802.11
add name=dhcp ranges=192.168.117.100-192.168.117.200
add address-pool=dhcp disabled=no interface=bridge1 name=defconf
/port
set 0 name=usb1
add authentication=mschap2 connect-to=**** disabled=no name=sstp-out1 password=**** profile=default-encryption tls-version=only-1.2 user=**** \
add bridge=bridge1 comment=defconf interface=ether2-master
add bridge=bridge1 comment=defconf interface=wlan1
add address=192.168.117.1/24 interface=ether2-master network=192.168.117.0
/ip dhcp-client
add address=192.168.117.0/24 gateway=192.168.117.1 netmask=24
/ip service
/system clock
/system identity
set name=****
/system leds
set 5 interface=wlan1
/system ntp client
set init-delay=0s
