how to make a ip address and ip gateway with same ip from dhcp
ex:
ip address: 192.168.1.10
netmask: 255.255.255.255
gateway: 192.168.1.10
i want to make this to my client hotspot
thanks
Dian
ex:
thanks
Dian
Hotspot? Why? With that setup, you won’t be able to access anything but localnet computers.
ADD: My bad. With that netmask, you won’t be able to access anything. ![]()
how but this… i take this sample from my laptop that connect to internet from mobile phone
PPP adapter HUAWEI:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-53-45-00-00-00
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 10.245.13.6
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 10.245.13.6
DNS Servers . . . . . . . . . . . : 124.195.15.100
202.152.165.36
Primary WINS Server . . . . . . . : 172.18.3.3
Secondary WINS Server . . . . . . : 172.18.3.4
NetBIOS over Tcpip. . . . . . . . : Disabled
C:\Documents and Settings\NC4010>
yup, the broadcast as itself ![]()
this our connections addresses and interfaces.
do you have problem with your connection…?
Windows IP Configuration
Host Name . . . . . . . . . . . . : nila
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : SURECOM EP-320X-R 100/10/M PCI Adapter
Physical Address. . . . . . . . . : 00-02-44-66-2F-BC
IP Address. . . . . . . . . . . . : 192.168.17.5
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.17.4
DNS Servers . . . . . . . . . . . : 202.155.0.10
202.155.0.15
PPP adapter VPN:
IP Address. . . . . . . . . . . . : 86.47.10.64
Default Gateway . . . . . . . . . : 86.47.10.64
DNS Servers . . . . . . . . . . . : 86.47.0.10
86.47.0.15
Primary WINS Server . . . . . . . : 86.47.0.11
Secondary WINS Server . . . . . . : 86.47.0.12
Again my bad. I thought we were talking about a MT device…
I have NO problems with ANY of my MT devices.
EDIT: OK, that was a lie. I have one RB133 V2.9.51 that has a hotspot that does not like to compensate for Daylight Saving Time. But what can you expect from non-supported hardware/software.
how to make my client hotspot obtain the ip gateway is same with ip address from dhcp
ex in mikrotik device:
ip hotspot: 192.168.1.1
netmask 32
ip gateway: 192.168.1.1
ip dns: 192.168.1.1
ip dhcp: 192.168.1.1
ip pool range: 192.168.1.10-192.168.1.254
so if my client obtain from dhcp its like this
client1
ip address: 192.168.1.11
subnet mask: 255.255.255.255
ip dns:192.168.1.1
but i want to like this
ip address: 192.168.1.11 <-----
ip gateway: 192.168.1.11 <----- ip gateway same with ip address
ip dns:192.168.1.1
how make this in mikrotik i use ROS 3.23
