I have a Samsung M2026W printer that used to work fine on my old router before update to Mikrotik
I have one HP AC2 as my main router and then two HAP AC lite hanging off in a Capsman config.
I cannot get the wireless printer to register on the network.
16:25:04 caps,info 84:25:19:31:34:6F@wlan-downstairs-cap-2ghz connected, signal strength -56
16:25:04 caps,info 84:25:19:31:34:6F@wlan-downstairs-cap-2ghz disconnected, 4-way handshake failure
16:25:05 caps,info 84:25:19:31:34:6F@wlan-downstairs-cap-2ghz connected, signal strength -62
16:25:05 caps,info 84:25:19:31:34:6F@wlan-downstairs-cap-2ghz disconnected, 4-way handshake failure
16:25:07 caps,info 84:25:19:31:34:6F@wlan-downstairs-cap-2ghz connected, signal strength -60
16:25:07 caps,info 84:25:19:31:34:6F@wlan-downstairs-cap-2ghz disconnected, 4-way handshake failure
I tried all sorts.
Removed access lists (ie dont drop weak signals)
disabled all firewall rules
made various changes to the security of my capsman… adding/removing encryption and connection types
added and removed b/g/n network settings.
I’m at a loss really now. What constitutes a ‘4-way handshake failure’?
Any help or suggestions would be very much appreciated.
Thanks.
