Samsung TV and Wifi
Hi everybody,
Happy new year :slight_smile:
I have bought a samsung tv model TQ55Q60DAUXXC in December and cant make it work with my wifi ax (capsman v2).
I have tried everything but strangely enough the tv connects to my phone hot spot using 2.4 and wpa2/wpa3.
What am I doing wrong?
Teach me masters.
 2025-01-02 14:57:30 by RouterOS 7.16.2
# software id = A4W7-3RQB
# model = RB4011iGS+
# serial number = F0*
/interface wifi datapath
add bridge=bridge-home disabled=no name=data-main
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-over-ds=yes name=security-main
/interface wifi configuration
add channel.band=2ghz-ax .skip-dfs-channels=10min-cac .width=20/40mhz country=Portugal datapath=data-main disabled=no mode=ap name=cfg-2-main-ax security=security-main security.authentication-types=wpa2-psk .encryption=ccmp .ft=yes .ft-over-ds=yes ssid=Wifi@Casinha
add channel.band=5ghz-ax .skip-dfs-channels=10min-cac .width=20/40/80mhz country=Portugal datapath=data-main datapath.bridge-cost=1 disabled=no mode=ap name=cfg-5-main-ax security=security-main security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes \
    ssid=Wifi@Casinha
add channel.band=5ghz-ax .skip-dfs-channels=10min-cac .width=20/40mhz country=Portugal datapath=data-main disabled=yes mode=ap name=cfg1 security=security-main security.authentication-types=wpa2-psk .encryption=ccmp .ft=yes .ft-over-ds=yes ssid=Wifi@Casinha
add channel.band=5ghz-ax .skip-dfs-channels=10min-cac .width=20/40/80mhz country=Portugal datapath=data-main datapath.bridge-cost=1 disabled=yes mode=ap name=cfg2 security=security-main security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes ssid=\
    Wifi@Casinha
/interface wifi access-list
add action=reject disabled=yes
/interface wifi capsman
set ca-certificate=auto certificate=auto enabled=yes interfaces=bridge-home package-path=/ require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled comment=sala2g disabled=no master-configuration=cfg-2-main-ax name-format=2GHZ-%I-ax- radio-mac=D4:01:C3:49:98:FB
add action=create-dynamic-enabled comment=sala5g disabled=no master-configuration=cfg-5-main-ax name-format=5GHZ-%I-ax- radio-mac=D4:01:C3:49:98:FA
add action=create-dynamic-enabled comment=escritorio5g common-name-regexp="" disabled=no identity-regexp="" master-configuration=cfg-5-main-ax name-format=5GHZ-%I-ax- radio-mac=D4:01:C3:49:B6:46 slave-name-format=""
add action=create-dynamic-enabled comment=escritorio2g common-name-regexp="" disabled=no identity-regexp="" master-configuration=cfg-2-main-ax name-format=2GHZ-%I-ax- radio-mac=D4:01:C3:49:B6:47 slave-name-format=""
Got anything in the logs?
    ssid=Wifi@Casinha
    Wifi@Casinha
You are setting two different authentication-types, while the SSID is identical.
Also you are overwriting the datapath settings, which makes no sense (when you have added /interface wifi datapath).
Better change it to:
add channel.band=2ghz-ax .skip-dfs-channels=10min-cac .width=20/40mhz country=Portugal datapath=data-main disabled=no mode=ap name=cfg-2-main-ax security=security-main ssid=Wifi@Casinha
add channel.band=5ghz-ax .skip-dfs-channels=10min-cac .width=20/40/80mhz country=Portugal datapath=data-main disabled=no mode=ap name=cfg-5-main-ax security=security-main ssid=Wifi@Casinha
add channel.band=5ghz-ax .skip-dfs-channels=10min-cac .width=20/40mhz country=Portugal datapath=data-main disabled=yes mode=ap name=cfg1 security=security-main ssid=Wifi@Casinha
add channel.band=5ghz-ax .skip-dfs-channels=10min-cac .width=20/40/80mhz country=Portugal datapath=data-main disabled=yes mode=ap name=cfg2 security=security-main ssid=Wifi@Casinha
As you don’t have any channels set, two configurations and provisionig rules are sufficient.
At the best in the logs from a lot of changes i get authentication timeout nothing more.
Tried your suggestion and ended up like this, still no luck. The manufacter said the tv should support wifi 5.
# 2025-01-07 23:41:04 by RouterOS 7.16.2
# serial number = F*********
add channel.band=5ghz-ax .skip-dfs-channels=10min-cac .width=20/40/80mhz country=Portugal datapath=data-main datapath.bridge-cost=1 disabled=yes mode=ap name=cfg-5-main-ax-my security=security-main security.authentication-types=\
    wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes ssid=Wifi@Casinha
Any one?
Can you change this:
To this:
add authentication-types=wpa2-psk connect-priority=0/1 disabled=no ft=yes ft-over-ds=yes name=security-main
add channel.band=2ghz-ax .skip-dfs-channels=10min-cac .width=20mhz country=Portugal datapath=data-main disabled=no mode=ap name=cfg-2-main-ax security=security-main ssid=Wifi@Casinha
add action=create-dynamic-enabled comment=sala2g disabled=no master-configuration=cfg-2-main-ax name-format=2GHZ-%I-ax-  supported-bands=2ghz-ax
add action=create-dynamic-enabled comment=sala5g disabled=no master-configuration=cfg-5-main-ax name-format=5GHZ-%I-ax-  supported-bands=5ghz-ax
Basically:
  • Only wpa2-psk support (at least for the time being)
  • Decrease bandwidth on 2GHz radio to 20MHz (some devices don’t like 40MHz)
  • Remove unnecessary configuration
  • Remove two unnecessary provision rules
In addition, have you removed and added the wireless network to the Samsung?
