Hi all,
I'm planning to replace my FRITZ!Box with an all-MikroTik setup and would appreciate a sanity check before I order everything. I have an IT background, but I'm new to RouterOS. My goals: VLAN separation, independence from any vendor cloud, a single management interface (RouterOS only), and minimal maintenance once it's running.
CONTEXT
- Telekom VDSL (Vigor 167 as modem, PPPoE on the MikroTik). Fiber expected in about 4 years.
- In about 2 years I'm moving to a house with roughly twice the floor space, so the setup should scale (more APs, PoE).
- About 70% of my devices are smart home devices (Shelly Gen1 and newer, Zigbee coordinator SLZB-06P10, printer). Two already existing FRITZ!Repeaters will connect wirelessly to the IoT SSID.
- Home Assistant runs on dedicated hardware (HA OS), plus several home servers (Proxmox, Docker host).
PLANNED HARDWARE
- Router: hEX refresh (E50UG), also running CAPsMAN
- Switch 1: hEX refresh (E50UG), uplink on ether2 (since ether1 is not on the switch chip)
- Switch 2: CRS310-8G+2S+IN
- 2 APs, which could be wall-mounted (see question below)
- DrayTek Vigor 167 later for VDSL
TOPOLOGY
Router -> wall socket 1 -> Switch 1 -> AP1 + Zigbee coordinator
Router -> wall socket 2 -> Switch 2 -> AP2 + Home Assistant + servers
VLAN PLAN (VLAN ID = third octet)
- 110 Main (192.168.110.0/24)
- 120 IoT (192.168.120.0/24, plus 192.168.178.0/24 temporarily on the same VLAN interface, so I can migrate devices from the old FRITZ!Box subnet step by step)
- 130 Guest (internet only, my work laptop goes here too)
- 199 Management (optional, maybe later)
Considered for later:
- 140 Server (192.168.140.0/24): Proxmox, Docker host, AI server, market data collectors. Main -> Server allowed, Server -> Main blocked.
- 150 Cameras (192.168.150.0/24): no internet access, only Home Assistant may connect. Only if I add cameras.
- 160 Work (192.168.160.0/24): wired port for the work laptop at my desk, as an alternative to putting it in Guest.
- 210 Lab (192.168.210.0/24): CHR test router and experiments on Proxmox, fully isolated.
- 220 DMZ (192.168.220.0/24): externally reachable services, e.g. a reverse proxy, separated from everything else.
KEY DESIGN DECISIONS
- Home Assistant is dual-homed: untagged in VLAN 110 (default gateway there) and a tagged VLAN 120 interface without a gateway. That way Shelly Gen1 CoIoT multicast and mDNS discovery work without reflectors or firewall exceptions, and IoT -> Main stays fully blocked.
- Printer in IoT. Two narrow exceptions: printer -> file server TCP 445 (scan to folder) and work laptop -> printer (TCP 9100/631, UDP 161).
- 3 SSIDs (Main / IoT / Guest), one VLAN each, local forwarding on the CAPs. IoT SSID on 2.4 and 5 GHz, WPA2, no 802.11r.
- RouterOS long-term channel, automatic updates at night outside of trading hours.
- Migration in phases: first behind the existing FRITZ!Box (double NAT), then PPPoE once VDSL is live.
QUESTIONS
- Does the overall plan make sense, or would you change anything fundamental?
- AP choice for wall mounting: I was planning on cAP ax mounted high on the wall. I ruled out the wAP ax because of reports about weaker 2.4 GHz range and only 256 MB RAM, and 2.4 GHz matters a lot with my smart home devices. Would any of you go for the new hAP be lite (Wi-Fi 7, USB-C powered, no PoE-in) instead? Or something else entirely?
- Is the hEX refresh fine as router + CAPsMAN for VDSL with PPPoE, or should I use the RB5009UPr as the router right away?
- Any pitfalls with multinetting two subnets on one VLAN during the migration, or with the dual-homed Home Assistant?
Thanks a lot!
Mike
