Could we get a sanity check on our config? We have our Core router CCR1072 with a 10Gb uplink to the internet (sfp-sfpplus1 vlan 803) . We have a 1GB fiber connection from the Core router (sfp-sfpplus3 vlan 3000) to SW1 CRS112 (ether1 vlan 3000). We then have a wireless Ubiquiti rocket AC lite link between SW1 (ether2) and SW2 CRS112 (ether1). The fiber link has a max MTU of 8900. The wireless link has a max MTU of 2024. We set the different interfaces on the Mikrotik router and switches to the max MTU supported by that link.
Download speeds before MPLS configuration was around 500Mb down at SW1 and 200Mb at SW2. After MPLS it dropped to 90Mb at both SW1 and SW2. We are eventually wanting to setup redundant wireless links and expand MPLS out to our other towers. We are not seeing any errors on any devices.
We did try disabling MPLS on SW1 and the Core with no improvement in download speed.
Core1
add fast-forward=no name=LoopBack
add name=PIP protocol-mode=none
set [ find default-name=sfp-sfpplus3 ] l2mtu=8900 mtu=8900
/interface eoip
add !keepalive mac-address=02:1C:12:38:E8:41 name=Core1-to-SW2 remote-address=10.200.0.3 tunnel-id=1
add !keepalive mac-address=02:8D:48:7D:E2:7D name=Core1-to-SW1 remote-address=10.200.0.2 tunnel-id=0
/interface vlan
add comment="MPLS" interface=sfp-sfpplus3 name="vlan3000" vlan-id=3000
add interface=sfp-sfpplus1 name=vlan803 vlan-id=803
/routing ospf instance
set [ find default=yes ] distribute-default=always-as-type-1 mpls-te-area=backbone mpls-te-router-id=LoopBack redistribute-other-ospf=as-type-1 router-id=10.200.0.1
add bridge=PIP interface=Core1-to-SW1
add bridge=PIP interface=Core1-to-SW2
add address=10.255.0.2/30 interface=vlan803 network=10.255.0.0
add address=10.20.0.1/22 interface=PIP network=10.20.0.0
add address=10.0.0.1/30 interface="LanLink - vlan3000" network=10.0.0.0
add action=src-nat chain=srcnat out-interface=vlan803 src-address=10.20.0.0/22 to-addresses=x.x.157.1
add distance=1 gateway=10.255.0.1
/mpls interface
set [ find default=yes ] mpls-mtu=8900
/mpls ldp
set enabled=yes lsr-id=10.200.0.1 transport-address=10.200.0.1
/mpls ldp interface
add interface="vlan3000"
/routing ospf interface
add interface="LanLink - vlan3000" network-type=point-to-point use-bfd=yes
/routing ospf network
add area=backbone network=10.200.0.1/32
add area=backbone network=10.0.0.0/30
/system identity
set name=Core1
SW1
set [ find default-name=ether1 ] l2mtu=8900 mtu=8900
set [ find default-name=ether2 ] l2mtu=2024 mtu=2024
/interface eoip
add !keepalive mac-address=02:A3:ED:52:A3:C9 name=Core-to-SW1 remote-address=10.200.0.1 tunnel-id=0
/interface vlan
add interface=ether1 name=vlan3000 vlan-id=3000
set [ find default=yes ] mpls-te-area=backbone mpls-te-router-id=LoopBack redistribute-other-ospf=as-type-1 router-id=10.200.0.2
add bridge=PIP interface=ether3
add bridge=PIP interface=ether4
add bridge=PIP interface=ether5
add bridge=PIP interface=ether6
add bridge=PIP interface=ether2
add address=10.0.0.2/30 interface=vlan3000 network=10.0.0.0
add address=10.200.0.2 interface=LoopBack network=10.200.0.2
add address=10.100.0.1/29 interface=ether2 network=10.100.0.0
/mpls interface
set [ find default=yes ] mpls-mtu=2024
/mpls ldp
set enabled=yes lsr-id=10.200.0.2 transport-address=10.200.0.2
/mpls ldp interface
add interface=vlan3000
add interface=ether2
add interface=vlan3000 network-type=point-to-point use-bfd=yes
add interface=ether2 network-type=point-to-point use-bfd=yes
add area=backbone network=10.200.0.2/32
add area=backbone network=10.100.0.0/29
/system identity
set name=SW1
SW2
set [ find default-name=ether3 ]
set [ find default-name=ether4 ] l2mtu=2024 mtu=2024
set [ find default-name=ether5 ]
/interface eoip
add !keepalive mac-address=02:3C:BA:67:20:97 name=Core1-to-SW2 remote-address=10.200.0.1 tunnel-id=1
set [ find default=yes ] mpls-te-area=backbone mpls-te-router-id=LoopBack redistribute-other-ospf=as-type-1 router-id=10.200.0.3
add address=10.100.0.4/29 interface=ether2 network=10.100.0.0
add address=10.200.0.3 interface=LoopBack network=10.200.0.3
/mpls interface
/mpls ldp
set enabled=yes lsr-id=10.200.0.3 transport-address=10.200.0.3
/mpls ldp interface
add area=backbone network=10.200.0.3/32
/system identity
set name=SW2
