It’s been a long time since I’ve manually played with firewall rules and I’m just hoping to get a sanity check.
I’ve got a hAP ax3 and used quick set to get my initial “simple” config working with VLAN1 using 10.0.0.0/24.
From there I added VLAN10 and a guest WiFi network running on 10.0.10.0/24. Then I added firewall rules to drop VLAN10 traffic not destined for WAN, unless it’s DNS queries to the router.
The setup works without issue, but I want to ensure I haven’t done something stupid and opened myself up to bad actors. That or if there’s a simpler way to do things.
I deleted the CAPsMAN rule that defconf creates as I don’t use it, and I’ve disabled the ipsec rules for similar reasons. Figured less is better in this situation.
established,related,untracked
invalid
in-interface-list=!LAN
disabled=yes ipsec-policy=in,ipsec
disabled=yes ipsec-policy=out,ipsec
add action=accept chain=input comment="allow dns queries from untrusted vlan" \
dst-address=10.0.10.1 dst-port=53 protocol=tcp src-address=10.0.10.0/24
add action=accept chain=input dst-address=10.0.10.1 dst-port=53 protocol=udp \
"drop all other traffic to router from untrusted vlan" dst-address=\
10.0.10.1 src-address=10.0.10.0/24
add action=drop chain=forward comment="isolate untrusted vlan subnet" \
out-interface-list=!WAN src-address=10.0.10.0/24
connection-state=invalid
