SAS Drive not found
Hi All.
I have posted this question earlier but in a nother thread i thought i would create a new one.
I have an issue with installing RouterOS 5.0 beta 3
We have a Dell R610 with the following spec
2 x Quad core 2.66Ghz intel CPU´s
2GB 1067 RAM ECC
146GB Segate SAS drive
When i try and install the routerOS software from bootable CD.
The errors appears as FATAL ERROR: no harddrives found
Thank for any help
Regards
Hiya,
Just to add.
We have PERC H200 SAS controller with a Seagate SAS drive
We want to install any version of RouterOS above 4.6 and preferably the latest.
Does anyone know what driver we need to use and how do we utilise this driver within the installation?
Regards
Hiya All,
Just wondering if there is a workaround, dont want to send the server back as it takes ages for turn around in spain.
Regards
SAS is not supported yet…
so,try sata HDD
RouterOS v5 beta3 and newer supports the following SAS/SCSI chipsets:
3w-9xxx
arcmsr
megaraid
Yours is probably different.
Hiya all,
We managed to work around the issue by netinstalling the software on a USB flash disk and then having the server booting off the USB drive.
The SAS or SATA drive and the CDrom didn´t work at all
Regards
