Satellite Download Limits
Unfortunately I live in an area where satellite interenet is my only option. Under the rules of their business plan, I am allowed 1250MB (1.25 Gb)downloads per day without falling under their “Fair Access Policy” (FAP) limitations which disrupts my service for a minimum of 24 hours.
I would like to know how I can keep track of the download limits on a real time basis. I have seen tools such as TORCH that will allow me to monitor “real time”, but as far as I can tell, it does not give me a cumulative total of the received transmissions.
Any advice here will be greatly appreciated. I need to develop a way of tracking and halting traffic when I approach this limit.
Are you in the US?
Yes, I am in South Mississippi
A real simple way would be to add a queue on the satellite interface - not perfect because it will lose the count if the board reboots, also it is (apparently) not 100% accurate. But for your purpose it should work fine.
Some questions! :confused: :laughing:
Do they count different there? confused by the usd maybe? Getting less each day for the same…
Sorry, its late here in euro land! :laughing:
Thanks for your help. I added a simple que to the interface, leaving everything as default. I was lookin in the total statistics section and I see a “Total Bytes” field. Is this for download and upload or just download.
How do I monitor just the total bytes dowloaded.
add firewall rule with action=passthrough (chain = prerouting, in-interface=your_sat_interface)
chain=prerouting is not available.
Input, Output and forwarding are the only available choices.
use mangle, not filter
Phil,
Email me. I have a solution for you that is probably cheaper and definitely better than Satellite. info at delmarvawifi dot com
Using firewall passthrough / mangle will essentially do the same thing as a queue and with the same limitations (except it will use less resources). The queue is a lot easier to monitor in real time though.
