satellite modem+mikrotik
is it possible to add mikrotik with satellite modem (Comtech 8psk tpc 10M, cdm 570) ???
i have a cable converter serial to ethernet, can i use it in rb1000 or X86??
need advice.
thnxs,
raktim
Yes you can use mikrotik as router from Satellite Modem ConTech CDM-570. But for that you need a
Syncronous Serial PCI Card attached with the PC and the serial card with connect with Sat Modem via cable.
Though the serial pci cards are expensive in compared with Cisco Serial cards.
regards
