I have limited download bandwidth and need to know when I am reaching my limit - I have seen a few different options such as splunk - I have a few Arm64 board which splunk core does not fully support.
how can I just get this info saved to disk from different interfaces? save to file every 5 min - I would then need to export the file Daily / Weekly / Monthly
Thank you in advance
:global time ([/system clock get time]);
:global hour [:pick $time 0 2];
:global min [:pick $time 3 5];
:global sec [:pick $time 6 8];
:global stamp ($hour . "_" . $min . "_" . $sec);
:global id ([/system identity get name]);
:global numports 100;
:global name "";
:global rx "";
:global tx "";
:global line "Interface Name, Avg RX Byte, Avg TX Byte";
:global line2 "";
:global filenumber 1;
:global buffer "";
:global newLength 0;
:global debug "";
:set $buffer ($line);
:foreach INTERFACE in=[/interface find] do={
delay 2s;
# record the parameters
:set name [/interface get $INTERFACE name];
:set rx [/interface get $INTERFACE rx-byte];
:set tx [/interface get $INTERFACE tx-byte];
# assemble them into a line
:set line2 ($name . "," . $rx . "," . $tx);
# add the buffer length and the string length
:set newLength ([:len $buffer] + [:len $line2]);
# check if the buffer would now be larger than the variable size limit
:if ($newLength > 4095) do={
# it is. write out the current line buffer (without the latest line)
# first construct the file name
:local fileName ($id . "_BW_" . $stamp . "_" . $filenumber . ".txt");
# create the file as it doesn't exist yet
/file print file=$fileName;
delay 2s;
# write the buffer into it
/file set $fileName contents="$buffer";
# increase the file number
:set $filenumber ($filenumber + 1);
# reset the line buffer to just the last line that hasn't been written to a file yet
:set $buffer ($line . "\n" . $name . "," . $rx . "," . $tx);
:set $newLength 0;
} else= {
# variable size limit would not be exceeded. add line to buffer
[:set $buffer ($buffer . "\n" . $line2)]
# write out the last buffer
delay 2s;
set $debug ("Im here");
The counters are preserved even on reboot, but (obviously) the intermediate values between two updates are lost if the device is rebooted.
/ip firewall layer7-protocol
:if ( ([:len [find where name=“ether1-total-upload”]] = 0) or ([:len [find where name=“ether1-total-download”]] = 0) ) do={
remove [find where name~“^ether1-total-(upload|download)$”]
add name=ether1-total-upload regexp=0
add name=ether1-total-download regexp=0
:local tupid [find where name=“ether1-total-upload”]
:local tdnid [find where name=“ether1-total-download”]
set $tupid regex=([:tonum [get $tupid regex]] + [/interface get ether1 tx-byte])
set $tdnid regex=([:tonum [get $tdnid regex]] + [/interface get ether1 rx-byte])
/interface reset-counters ether1
:local currUpload [:tonum [get $tupid regex]]
:local currDownload [:tonum [get $tdnid regex]]
:put “Current Upload is $currUpload and current Download is $currDownload”
I cobbled together this code from what I read on the forums - it’s creating a file and sending it via FTP to a server - now to find how to import these files into a new gui
just to be clear I am no developer can copy past code at best
:global fetchdate [/system clock get date]
:global stamp ($fetchdate . "_" . $hour . "_" . $min . "_" . $sec);
:global name "";
:global rx "";
:global tx "";
:global line2 "";
:global buffer "";
:global debug "";
# Set params for FTP
:local ftpuser "user"
:local ftppass "pass"
:local ftpaddr "192.168.1.24"
delay 2s;
delay 2s;
:set $newLength 0;
} else= {
delay 2s;
# Upload files to FTP
:delay 15s
/tool fetch address=$ftpaddr src-path=$fileName user=$ftpuser password=$ftppass port=21 upload=yes mode=ftp dst-path=/home/ubuntu/data/mikrotik/$fileName
:delay 15s
# Remove files from device
/file remove [find where name=$fileName]
If I am pulling data from the interface
does that still stay after reboot? is it it better to pull from the firewall rules?
