Save Rx Byte and Tx Biyte in a file
I try, in Simple Queues, to save Target-Address and Total Rx Bytes and Total Tx bytes in a file, but when I use:
/queue simple print bytes file=bytes
I can only see Rx and Tx like this: 46825438/6…
Is there a way so I can see the whole number of bytes
Erik
There doesn’t seem to be a switch to make it show the entire column. Maybe try
/queue simple print stats
instead, though it contains different columns one of them shows the bytes transferred.
