Hi guys!
I’m trying to create obtain the package version of one npk file and store it into a variable, but in every way i tried, my variable stills empty.
:local packageVersion (/file get (find ".npk") package-version)
:put $packageVersion
Can somebody help me with a solution please?
the file is called .npk?
why you use () ???
No the file is named as a mikrotik firmware, something like "routeros-arm-6.49.10.npk". I noticed this after posting, i changed to:
:local packageVersion [/file get [find type="package"] package-version]
I didn't even think about the use (), i'm kind new to scripting, thanks for the hint!
It's working with the script above. Thanks man!
Amm0
April 10, 2024, 2:44pm
4
If you know Linux/UNIX, the are similar to `` backtick to run a command and replace result in-place.
Yes and the new way of doing this in UNIX/Linux, not using back tics chars. is like this.
Use dollar sign and regular parentheses.
$(cat /etc/passwd)
Amm0
April 10, 2024, 4:18pm
6
It’s likely better thinking of the RouterOS CLI in terms of a REPL for a programming language, than ANY UNIX shell.
It’s thinking CLI is more like Linux/UNIX is where the trouble starts
FWIW, I’m not sure $() is newer than ``. The $() is more for variable assignment IMO, while backtick works anywhere.
