I have “travel router” based on rbm33g.
I would like to have possibility to save connections stats after the powering off the router.
If there is any possibility to save that info into a file on disk(microSD card) periodically ?
Something like scheduler script which will dump that info into text file to disk ?
regards
SiB
May 18, 2020, 8:46pm
2
If you can still use the USB port then you can insert usb adapter with SDcard and just use /disk1/directory/file.txt
tryuys
May 19, 2020, 12:46pm
3
Yes, but I dont know the script body/language…
I hope that could be some ready to use written before.
SiB
May 19, 2020, 1:26pm
4
Then learn it.
What you want exacly, you write general question, I answer you general answer.
bpwl
May 19, 2020, 2:47pm
5
See http://forum.mikrotik.com/t/interface-data-quota/79514/1
Be aware of the correction for reboots a bit lower.
Using this on 3 SXT LTE kits. DUDE is also reading the result file for reporting.
But DUDE is also collecting the data without any script, and making diagrams after data compression (average span depending on the time period requested)
