Saving open dialog boxes in RouterOS
Heya guys,
Just have one small question here:
See, I have these windows, like ping, torch, interface, and such already open in router os, right? Set up just the way I like it.
Problem is, whenever I rebooted the router, these window would disappear. I would need to reopen each one and put them in the position I like. Is there a way to save these open windows’ information? Location, size, what windows are open, and such? This is not really a problem, but it gets annoying after a while. ^^
Thanks much.
Follow parrini’s advice here: http://forum.mikrotik.com/t/can-connection-tracking-be-disabled/23241/1
-Louis
Letni,
Thanks for replying, but I don’t see any posts by parrini in the thread you gave me.
Could you maybe check the link again? ^^
Thanks again.
Sorry, Try this one. http://forum.mikrotik.com/t/ros-v3-x-winbox-question/22539/1
-Louis
Hmm… That’s not quite it. I know about the “Load previous session” thing, and I have no problem when the router is on.
The problem is, when the router is rebooted/turned off, the “load previous session” checkbox doesn’t work. Whether it’s checked or not, it still loads an empty winbox after a reboot. :frowning:
Are there any way to save these settings to, say, a text file or something? So I can just load the config file the next time I start winbox after a reboot…
Oh well…
Any other ideas?
A big Ditto on this issue !! Also, making it easier to select the “show columns” items so I don’t have to keep dropping the pull down each time. How about setting it so I can do multiple selections with one pull down of the menu. As well, auto-sizing of the columns
Just my 2 cents
-tp
