Does anyone know of an SC fiber ethernet controller that works with Mikrotik? I could only find one DLINK but no one in the US sells them. I purchased a D-Link DGE-550SX by mistake but it’s not showing up in the interfaces. ![]()
Any recommendations?
You could probably use an SX to TX convertor / adapter / tranceiver i think thats what its called . Then hook that into any gige over copper like Intel Pro 1000/MT … should work. YOu can use convertors for Cisco ports SX ->TX or TX->SX so you should be able to use the same here
Yes, we have the convertors but we didn’t want to add another power adapter to the mix or take up any more space in the small cabinet.
Thi Intel / Compaq 64bit Gig card wirks (I have been using one in a 32bit system for over 2 years.. (Like a ROCK) Works GREAT…last long time !!!
Craig
that’s Intel, you didn’t expect anything else than excellent reliability and service - did you? ![]()
What’s the model number of the Intel/Compaq card?
