Scan does not show all Freq.
I have a 411 running 3.22 OS with extended Freq Lic. with 8602 radio. When I am scanning my networks driving I do not see all of the Freq that I should be seeing. Now I can put a Gateworks board (2347) running Ikarus with the same antenna and radio and I see them. The 411 is set on superchannel and no country selected. I have tried different settings and no changes.
Anyone have a suggestion as to why one sees them and the other doesn’t?
TIA
For superchannels you need to set a range in the scan list. For example for 5GHz use 5100-5900. Otherwise the default scan list is only the standard regulatory range.
Tom
That did it.
Thank you so much.
