Is there a way to upload custom scan-lists for use by atheros based cards?
not directly. you can only add frequencies like this :
/interface wireless set wlan1 scanl-list=default-ism,2442,2345
basically you could make an export file, modify it and then import in where you want. interface wireless export. and import.
Whats the point to add new frequencies to scan list, since you cant set-up your access point to transmit on them ?
i tried yesterday to add 3 more channels to scan list, but i couldnt setup the access point to use them..
normis:
phendry:
interface wireless export. andimport.Whats the point to add new frequencies to scan list, since you cant set-up your access point to transmit on them ?
to use the frequencies 2.5 ~ 2.7; 5.47 ~ 5.725Ghz you need a special license in the mikrotik. you’ll have to contact support to get that
Lewis:
normis:
phendry:
let me laugh…
i will get the answer after the Beijing Olympics..
I sent them a mail to replace a licence in 27/5.. I resent it twice..
still no answer..
let me laugh…
i will get the answer after the Beijing Olympics..I sent them a mail to replace a licence in 27/5.. I resent it twice..
still no answer..
i’m answering this post, so you shouldn’t be so sceptical. if you didn’t get an answer, try again because i answer 100% of license concerning emails at the same day
let me laugh…
still no answer..i’m answering this post, so you shouldn’t be so sceptical. if you didn’t get an answer, try again because i answer 100% of license concerning emails at the same day
I tried twice.
Anyway, thank you very much, I’ll catch up Athens Olympics ;))
They were two very bad days.. my CF stopped working after an upgrade, you asked for old software ID, comments were disappeared from licence entries in your site, then your site stopped working (backbone problem ?).
i had a spare MT installed on a 2,5 HD, so i used this..
thank you very much..
i had a spare MT installed on a 2,5 HD, so i used this..thank you very much..
i’m glad your problem is solved ![]()
