Scan problem ?
Hello , i m trying out some wireless routers for a wireless network and i tried my luck with mikrotik too. Everything went fine except for a weird scan problem . While i was scaning with my laptop running kismet from my rooftop i see all SSID’s normal . With networkstumbler again everything is normal . When i tried with a mikrotik box some of the SSID’s appeared as boxes !!! I mean no ssid name (ex “MyLAN”) and at the SSID’s name there was some strange boxes ( something like ) . I tried the console scan and at the SSID’s that i could not see ( because of the boxes ) in winbox , now i could see something like this :
Flags: A - active, B - bss, P - privacy, R - routeros-network, N - nstreme
      ADDRESS           SSID                          BAND       FREQ SIG RADIO-NAME
ABP   xx:xx:xx:xx:xx:xx Normal_SSID            2.4ghz-b   2412 -84
AB    xx:xx:xx:xx:xx:xx [b] \00\00\00\00\00\00\00\00\0...[/b] 2.4ghz-b   2447 -83
Any idea what is causing this ? ( kismet and stumbler ssid is ok and at mikrotik i see boxes or zeroes )
Please excuse my english :wink:
ok maybe my english are to bad to understand what i am trying to say :laughing:
Here is a picture of the problem :
As you can see in some SSID’s i just get instead of the name … when i do laptop + netstumbler scan i see all SSID’s normal
Is there something i can do to fix that ?
We get that in our city, its some sort of proprietory equipment I am told…
Hi ! , thanks for your reply :smiley:
Your expression “proprietory equipment” means some device that uses 2.4Ghz but is not compatimble with 802.11b/g and so we get instead of SSID ?
Why using netstumpler i can see the SSID (or kismet) and while scaning using mikrotik i dont ? :open_mouth: Im sure its the same devices because of the MAC …
Its disturbing … :frowning: :imp:
