Scan wireless on R52nM
I want to buy RB411AH with R52nM wifi Card where will be connected 2 antennas and I will want to discover neigbour sites in winbox via scan (or snoop) in wireless tab, on which antenna will perform this scan? It can be performed this scan on both antennas together or I must select only one antenna?
So, it will be possible with wifi card above or R52Hn discover Mikrotik SXT 5HnD unit?
I want to use this solution for wardriving and R52nM with connected 2 antennas should give me maybe more results than only one.
Thanks.
Martin
