SCEP and https URLs: failure: Not a HTTP URL!
Hi all,
When adding a SCEP server that is part of a wider SSL secured server, the following error occurs:
[minfrin@router] /certificate> add-scep template=test-name scep-url=https://interop.redwax.eu/test/simple/scep
Are there plans to fix the SCEP client so that it can connect to an SSL server? Using an insecure endpoint, while in theory acceptable in SCEP, raises unwanted compliance questions.
Regards,
Graham
Hi Graham,
do you have fixed your problem?
We have right now the same issue we have only the chance to use a HTTPS URL.
Regards
Ralph
