I’m trying to set up the scep client on a 411 but I can’t set up the “store-name”.
When I add the client I’m asked to enter a “store-name” and no matter what I enter I get the following -
failure: At least one field specifying certificate name must be set!
Has anyone had any success or know what I’m doing wrong?
One more thing, the SCEP server is listening on port 8777 but I’ve noticed that the requests from the RB are sent to port 80.
Is there a way to change the port?
and I don't understand what I have to enter
> You have to enter one of certificate fields, just as error says, common-name, serial-number or any other.
Where can I find step-by-step HowTO setup "SCEP Client". [Here](http://wiki.mikrotik.com/wiki/Manual:System/Certificates#SCEP) is minimum info.
Thanks in advance
I’ve found right path but ded SCEP client dosn’t work normal.
there are CA server logs:
Feb 20 14:28:18.681: CRYPTO_CS: received a SCEP GetCACaps request
Feb 20 14:28:18.681: CRYPTO_CS: Capabilities sent
Feb 20 14:28:18.741: CRYPTO_CS: received a SCEP GetCACert request
Feb 20 14:28:18.773: CRYPTO_CS: CA certificate sent
Feb 20 14:28:25.565: CRYPTO_CS: received a SCEP request, 3052 bytes
Feb 20 14:28:25.565: CRYPTO_CS: failed to base64 decode request
