I have a script running on all of my ap-bridges, that checks if the wireless interface is running every 5 minutes. Don’t ask me why sometimes a wifi interface stops running for a reason, and the only thing to do is disable and enable the interface to let it come up again…
The problem is that i schedule this script in the scheduler every 5 minutes, and works great. BUT … when when I reboot the ap-bridge the script doesn’t run anymore. I have to change the date and time manually for each schedule to let it work again. Ofcourse this is a 2 minute job, but I want to let the schedule do his job automatically after a reboot.
I use a public time server on every ap-bridge. is this the problem? when the ap-bridge has been reset, it uses the time and date 1 jan 2000 for some seconds, and then 'reset’s to the actual time and date.
I hope someone can help me out with this. I use versions 2.8.20 untill 2.8.28 on several ap-bridges.
If the system time is before the sheduled time, changing the system time won’t help. It seems the system time has to “pass” the time the scheduler is set to to invoke it.
Try this:
Set the time the scheduler is to start to a time you know is earlier than the system time will be on boot e.g. Jan/01/1970. The system time will now be later than the time set for the scheduler and the script will run no matter what the system time is at boot.
Has anyone confirmed this workaround? Only problem is that different OS releases have different startup times (I seem to remember) so what date do you use? Early as possible?
We also have the same problem - scheduled scripts do not work after a reboot, and only by changing the start date/time to start after the current NTP time will it start again…
I might have misunderstood your problem, but since the earliest date I can set on the system is jan/01/1970 00:00:00, then any time that the system will have after a reboot is later than this time.
From this follows that the scheduler will start any scripts scheduled before the actual system time. Hence the script will be run at startup since the system time can not be earlier than jan/01/1970 ???
So I made a script with name script1 and then added the script to the scheduler to be run at jan/01/1970 at 00:00:00.
NTP doesn’t help - and only really necessary on the RB 500’s, as there is no CMOS battery. RB230 seems to be ok…
It seems that after a reboot of RB500, the time resets to the default, then synchs with NTP and the scheduler original start time is then before the current time (NTP synch), so it never starts again…
Maybe if you set the start time to be the same as the RB500 default, then the scheduler might run at the time of booting, but this is a headache on many routers that get upgraded periodically, as the default time changes with each revision…
Also, I have a few scheduled scripts that need to run at different times - eg backup, email backup then reboot… if I set the scheduler to run at the system startup time, then the router will be locked into an infinite reboot loop…
im used script and schu but not work and return to default time , coz the ap-bridge don’t have NAT to Service over the Internet , so don’t good this script , you want to work that , do manually reboot the ap-bridge every day …
