I have a script installed in my Mikrotik router, but it´s not running in the desired time.
Can you tell me what´s wrong here ?
You didn’t specify any script to run “on-event”
Thanks a lot.
My script didn´t run at the specified time, am I forgetting anything ?
In the field “On Event” I put the script name: “Mac-Change”
Are you sure that the script is syntactically correct ? Script with errors could not “run”.
The script is working fine, when I run it I get the message in the Log area:
New MAC 602d0cbf1d28
And the router´s MAC addres is changed, but it´s not running in the scheduller.
Need I mark any option in the “Policy” area ?
It doesn’t say much
post the code of your script.
I got the script from this forum:
http://forum.mikrotik.com/t/script-to-change-mac-address-and-get-a-new-public-ip/93104/1
I created a new schedul - Let´s see tomorrow what´s happen…
Your On Event should read
/system script run Mac-Change
No, it is enough to specify valid script name.
I have had issues with that in the past, so I have always put the whole command in.
Unfortunately my scripts didn´t work. The router´s mac addres wasn´t changed, and I can´t see any data about
Mac changes in the log area:
When I run the script by hand I can see the information in the log area:
Do both the script and the schedule have full permissions?
Can you tell me how enable permissions in the scripts ?
In the “Policy” section. Try marking all of the boxes.
Also, if you post the script, we can test it and see what’s going on.
This is the script:
I did your recommendation and check all box in the Policy area:
Let´s go to see what´s happen tomorrow…
Problem solved !
Thanks a lot for your answers .
Glad to have helped.
