Is MT going to do anything to fix the problem with scheduled scripts on reboot and the use of NTP?
I cannot get my scheduled scripts to work after reboot either, and I have multiple routers deployed that get rebooted regularly and manually resetting the start time on each script in each router is just plain silly…
I guess until this is fixed, I need to not use NTP? Can anybody think of a better idea at this point. Please advise. Thanks
Same thing here, I’m having problem with NTP and schedulles.
Not firewalled but still not updating time, making problem to schedulles.
Generally it wouldn’t be a problem but rb532 after each reboot resets the time…
Yes but I have problem with time, for date I don’t care. I have scripts that needs to run on specific time of the day and now I have problem doin’ it manually
I am trying something which may work, and I will let you know if it works for me. Since scripts which run often (like every minute) run no matter what time of day the router has, the following script will run every minute, and if the router has recently rebooted, it will remove a scheduled script and write it again in the scheduler. Therefore, the script should run on time the next time it is called. After the schedule is rewritten, the script no longer rewrites the schedule again even though it checks every 1m to see if it need to rewite them. The example is below.
djape: It looks like my timed scripts are working ok. I had an event ,which is set to run at 3am every morning, and it just ran a few minutes ago at 3am. So I guess the work around I posted above actually works. Let me know if it helps you too.
In my case scheduller will show count as everything is ok, but never executes…
This happened from 2.9.17 and even now on 2.9.20 is the same. Yesterday I did system reset and did router from the begining, still the same…
It’s simple p2p connection script to enable and disable firewall rule.
Main problem is that ntp client sometimes picks the time and sometime don’t.
No firewall rules to drop ntp traffic…
That is interesting. I have all of my rb532a running 2.9.18 and one running 2.9.20 and the workaround I recommended seems to be working very well. I actaully have the router also rebooting itself every night, and then after reboot it resets the scripts and then executes flawlessly. The only problem I have encountered is when script try to execute at the same time, they wont work.
