in all rc version scheduler does not start jobs, it starts only when winbox is lunched… in my opinion there is a bug…
You should check forum and you find the same topic.
Yeap, there is a problem with it, it works only with open terminal or telnet connection established to your router.
this will be fixed in a new version,.
