I use schedullers big time.
Few months ago I have posted a problem with scheduller not exectuning at all.
Somehow I tried everything and found that scheduler is working if I change start date to current (which leaves me to change it every morning).
It was not a big trouble cause it was just a few MTs on my network and rest of them (various 2.9 versions) where working properly.
But yesterday I upgraded all to 2.9.34 and not even a single one executed schedulles?! RB532, rb112, a PCs all together
Now I’m in trouble as I need to execute scripts manually on more than 50 routers.
This was posted before from different members and never taken seriously by MT team.
Please, can someone investigate a problem.
I can send suppout from all MT’s but somehow don’t see how would that help. It’s a simple p2p accept and drop schedulle…
i have the same problem here on differnet versions of 2.9 - if i set the start time to the actual date then it normaly works until i reboot the box
then no more scedueled script is started - after setting the date back to the actual date it works again …
so do not reboot the boxes )
Read more carefully, he don’t have problem with system time. Problem is start date in scheduller. I have the same problem. If I set system current date scheduller will work, but tommorow it will not if don’t change start date again to tommorows date.
Sorry to say, but I find this to be very serious bug.
It’s 2.9.34
Never used 2.9.31 but same thing is on 2.9.28 which I used before upgrade. I can’t recall in what version this problem was introduced. But it was few months ago, and I try to upgrade regularly.
based on your report, we have fixed the following bug:
if until the next scheduled time, the remaining time is less than interval/2 - then after set and reboot, the scheduler was skipping one run time (it would have started the day after tomorrow).
