scp and wildcards
Does RouterOS support wildcards with scp?
I searched the forum but found nothing obvious.
Using scp I want to pull backups from a Mikrotik device to an off-device storage location. The scp command on my system supports wildcards and works fine but fails with Mikrotik devices. The result is always “no such file or directory!”
I can use scp to pull full file names with no wildcards but not when using wildcards. Single and double quotation marks and backslash escape makes no difference.
If scp on RouterOS does not support wildcards, what is an appropriate work-around?
Thanks. :slight_smile:
