Screenshot's for inspiration
I have found seral methods how to make the net workmap more clear.
Could you post some screenshots for inspiration?
Thank you.
Wow! Some cleaver tricks there. Never thought of making ports static objects to organize the links that way… And really nice how the “submap” look like Christmas ornaments connected to the “static” objects. Although you make it look easy, that was a TON of work and near the limits of The Dude.
thank you much.
the ports is networks( needs to be networks, because of the real links between them)
And talking about drawings, what program or app or web app do you use ??
I have to web apps to share links to:
https://app.diagrams.net/
https://excalidraw.com/
LOL, if only excalidraw would help… In the Dude, it more like programming the “map” than drawing. And the Dude has some very fix rules how items on the map interact (and some are device or links – which have restrictions).
e.g. stuff like @voodoovood points out, the speed shown comes form a “link” but those need to bound to a non-static thing on one end – so map uses a network to “workaround” some of Dude’s limitation on what you can “draw”:
And all the text in Dude is generated from complex Excel-like formulas specific to The Dude. Why voodoovood work is impressive to make it look as clean as it does.
And some related topics/posts
  1. Show us your map
  2. Dude v6/v7 - Feature request list/#4
