Hi all,
im looking for a script to telnet a server (192.168.5.100) and execetute a command…
Hi all,
You can’t do that from RouterOS.
you have to use linux with ssh for that - set up non-interactive login using certificate.
after that you can execute commands using ssh or create tcl scripts.
Somewhere at the forum i saw few commands and i tried my script:
/system telnet 192.168.0.1
:delay 10
:put "password"
:delay 10
:put "restart"
but northing ![]()
this is simple script, that assuming, that 192.168.0.1 is RouterOS connects to it, then from there using mac-telnet conencts to box with known mac address and sets up ip address, identity, default gw and enables api on router, then disconnects and quits.
i run this on ubuntu box with expect installed on it.
because you cannot run that dirrectly from routeros but expect is “emulated user”, that sees output, and reacts on it.
#!/usr/bin/expect
set mac [lindex $argv 0]
set ip [lindex $argv 1]
set ses 1
set $::env(TERM) xterm
spawn "telnet" "192.168.0.1" "-l" "admin+ctw80h25"
set ses $spawn_id
set timeout 200
expect -i $ses "Password:"
exp_send -i $ses "\r"
expect -i $ses "*admin*@*MAC*]*>"
exp_send -i $ses "/tool mac-telnet $mac\r"
expect -i $ses "Login:"
exp_send -i $ses "admin+ctw80h25\r"
expect -i $ses "*admin*@*]*>"
exp_send -i $ses "/ip address add address=$ip/24 interface=ether1\r"
exp_send -i $ses "/ip route add gateway=192.168.0.1\r"
exp_send -i $ses "/ip service enable api\r"
exp_send -i $ses "/system identity set name=$ip\r"
exp_send -i $ses "/tool bandwidth-server set authenticate=no\r"
close
