I’m using that one script for updating static entries at ccr:
if [ -e netdevices_murka_1 ]
then
for x in $(cat netdevices_murka_1 | awk ‘{ print $1 }’)
do
ssh admin@1.1.1.1 “/ip arp remove [ /ip arp find where address=$x ];”
done
a=0
b=0
c=0
for item1 in $(cat netdevices_murka_1 | awk ‘{ print $1 }’)
do
a=$a+1
array1[$a]=$item1
done
for item2 in $(cat netdevices_murka_1 | awk ‘{ print $2 }’)
do
b=$b+1
array2[$b]=$item2
done
for item3 in $(cat netdevices_murka_1 | awk ‘{ print $3 }’)
do
c=$c+1
array3[$c]=$item3
done
I’m looking for a microtic script, which will parse txt file with ip,mac,interface and will set up it on board. For this momment ssh remote commands are too slow for me ;-(.
I cant find usefull microtic scripts examples with arrays ;-(.
Best regards.
I would not worry about using arrays and use bash to create a properly formatted importable .rsc script. The bash script could look something like this:
# create MikroTik script file
echo "/ip arp" > import.rsc
then
a=0
b=0
c=0
for item1 in $(cat netdevices_murka_1 | awk '{ print $1 }')
do
a=$a+1
array1[$a]=$item1
done
for item2 in $(cat netdevices_murka_1 | awk '{ print $2 }')
do
b=$b+1
array2[$b]=$item2
done
for item3 in $(cat netdevices_murka_1 | awk '{ print $3 }')
do
c=$c+1
array3[$c]=$item3
done
else
echo "nie ma pliku"
exit 0
fi
# add data to the rsc script
x=1
z=`cat netdevices_murka_1 | wc -l`
while [ $x -le $z ]; do
echo "remove [ find where address=${array1[$x]} ]" >> import.rsc
echo "add address=${array1[$x]} mac-address=${array2[$x]} interface=${array3[$x]}" >> import.rsc
x=$[x+1]
done
# upload rsc file to router
ftp -n 1.1.1.1 <<END_OF_SESSION
user admin password
pass
put import.rsc
bye
END_OF_SESSION
# delete local file
rm import.rsc
# import rsc file on router, and then remove
ssh admin@1.1.1.1 "/import import.rsc"
ssh admin@1.1.1.1 "/file remove import.rsc"
# might be able to run them on one line? Not tested...
# ssh admin@1.1.1.1 "/import import.rsc;/file remove import.rsc"
Running the bash script creates import.rsc file from your mysql data:
/ip arp
remove [ find where address=192.168.193.251 ]
add address=192.168.193.251 mac-address=00:0C:42:89:DC:FD interface=vlan23
remove [ find where address=192.168.195.240 ]
add address=192.168.195.240 mac-address=00:0E:2E:A7:F6:CF interface=vlan25
remove [ find where address=192.168.188.251 ]
add address=192.168.188.251 mac-address=00:15:77:2E:B6:40 interface=vlan18
remove [ find where address=192.168.191.252 ]
add address=192.168.191.252 mac-address=00:15:77:2E:C4:40 interface=vlan21This file is uploaded to the MikroTik router via FTP and runs via SSH and is then deleted.
